Reply
Password problems
Dpro
Follower
Password problems
Hi my router keeps kicking me off the 2.4 network then when I go to log back in it tells me it’s the wrong password.
I then log into the router look at the password it’s the same as I am typing I click apply and then try to log into it again and it works for a day or so then it does it again.
Please help
Model: D7000|Nighthawk AC1900 VDSL/ADSL Modem Router
Message 1 of 2
DarrenM
NETGEAR Moderator
Re: Password problems
Try to remove the wireless network from the settings in your wireless device then try to connect again see if that resolves the issue.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 204 views
  • 0 kudos
  • 2 in conversation
Announcements
