Reply
Performance Problems - Nighthawk X6 AC3200
NWest1965
Hi Community, hoping somebody can help me out here.  I just bought a Nighthawk X6 AC3200 to improve WIFI performance but it almost seems like it has made it worse.  My Nighthawk is connected to my Plusnet modem/router which now has its WIFI functionality switched off.  Other thing to bear in mind is that I've got three DEVOLO devices plugged into the mains to act as WIFI range extenders.  What I'm wondering is what is the best way to troubleshoot this.  I don't have a big house, but the ground floor is spread out a little and it is at the extremities that I'm struggling with speed issues.  Thanks for any help you can provide.
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 2
Guru
Re: Performance Problems - Nighthawk X6 AC3200
How is the router placed? Centrally is preferred.
I would disable ALL wifi extenders and test for speeds. Extenders are not known for speed and can impact some performance.
Any other wifi neighbors near by? If so, how many?
How big is your house?
My Setup (Cable 1Gbps/50Mbps)>CAX80 v2.1.2.1(LAG Disabled)> RBK953(v6.0.3.68) & XR450(v130)
Additional NG HW: C7800/CM1100/CM1200CM2000, Orbi CBK40, CBR750, RBK853 v4.6.3.16(AP) & RBK752 v4.6.5.14, RBK50(v22), SXR30(v110), R7000(v34), R7800(v84), R7960P(v82), EX7500/EX7700, and WNHDE111
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 326 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
