Orbi WiFi 7 RBE973
Reply
Phone can’t connect through R7000
R7000_uzer
Can’t connect to a lawn mover.
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 9
R7000_uzer
Re: Phone can’t connect through R7000
It did work earlier with another router and the R7000 do find both the phone and the lawn mover.
Message 2 of 9
R7000_uzer
I guess this forum is usless.
Model: A7000|Nighthawk AC1900 WiFi USB Adapter - USB 3.0
Message 3 of 9
antinode
Guru
   Something is useless.  You might benefit from the results of a Web
search for:
   "life is like a sewer"
> Can't connect to a lawn mover.
   "Can't" is not a useful problem description.  It does not say what
you did.  It does not say what happened when you did it.  As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
   Is a "lawn mover" anything like a "lawn mower"?  Do you think that
any of your readers knows which make and model "lawn mover" you have?
> It did work earlier with another router [...]
   Not a very detailed description of that device, either.
   Nothing to do with anything?
Message 4 of 9
R7000_uzer
Ok, yes a worx landroid wg796E.1 and the other router was a Comviq something…
Message 5 of 9
@R7000_uzer wrote:
Ok, yes a worx landroid wg796E.1 ...
This?
81Del2aU1IL._AC_SL1500_
What do you want to do with it?
@R7000_uzer wrote:
...the other router was a Comviq something…
What's that?
Message 6 of 9
R7000_uzer
Yes correct,
I want error message when it can’t continue mowing. Never mind, I don’t have the comviq router anymore.
Message 7 of 9
Does that mean that your problem is solved?
You aren't making it easy for anyone to understand what is going on at your end and what you want to do.
Message 8 of 9
R7000_uzer
Maybe not, I just don’t want to bother poeple to much
Message 9 of 9
Top Contributors
Discussion stats
  • 8 replies
  • 1223 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
