Reply
Please help me! R6700-100NAS poor internet speeds!
S_salanitri
I have Spectrum ISP. Pulling 425+ from the modem but less than half from the Nighthawk. Called Netgear and they were only apple to give me minimal tips... Channels, Fragmentation Length, CTS/RTS.... all to no avail. Flashed the firmware, installed previous firmware, reset.... nothing. Any assistance appreciated! It worked great with the Spectrum router and Ethernet from the modem is rippin’, so I know thats not the issue. It’s either Spectrum hates 3rd party routers or I need help. Thanks!
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 3
DarrenM
NETGEAR Moderator
Re: Please help me! R6700-100NAS poor internet speeds!
Do you have just a modem from the ISP or it's it a combo modem router? If it has a router built-in have you disabled it? Do you have QoS enabled on the router? if so try to disable it.
Message 2 of 3
S_salanitri
Thanks! I found out, to my ignorance, that this specific model is not compatible to with my ISP Charter Spectrum.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 216 views
  • 0 kudos
  • 2 in conversation
Announcements
