- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Please help, my Nighthawk x6 r8000 randomly drops internet connection
- Mark as New
- Bookmark
- Subscribe
- Permalink
My set up is CM400 cable modem (Cox Cable) connected to my Nighthawk R8000 X6 AC3200 tri-band router with Firmware Version V1.0.4.46_10.1.63 I've never had an issue with but but since last firmware update my internet started to drop at random time throughout the day up to 3 time a day for about 2-3 minutes. All the lights on the modem stay green and all the lights on the router stay white except for the internet light which turns amber. If I do a power cycle and reset the modem signal from Cox cable it seems to be fine for a day or two before it happens again. I don't have the know how to diagnose the issue myself and Cox can't figure it either they just try to sell me their modem and router, lol.
I'd appreciate any help I can get.
Thanks.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
> [...] since last firmware update [...]
To me, that sounds like a clue. "Newer" and "better" are spelled
differently for a reason. I'd try loading the previously working
firmware.
Visit http://netgear.com/support , put in your model number, and look
for Downloads. (For older versions, under Firmware and Software
Downloads, look for "View Previous Versions".) Find the kit(s).
Download the kit(s) you want. Read the "Release Notes" file for
instructions.
Recently, Netgear has stopped including actual instructions in its
firmware "Release Notes" files, so all you may see there is a hint like:
To update your router's firmware, follow the instructions in your
router's user manual.
In that case, visit http://netgear.com/support , put in your model
number, and look for Documentation. Get the User Manual. Look for
"firmware" and/or "update" for the details.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
firmware.
instructions.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Please help, my Nighthawk x6 r8000 randomly drops internet connection
Thanks again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't know what to do next. It seems like it times out ever 72 hours or so.
- Mark as New
- Bookmark
- Subscribe
- Permalink
