Reply
Alanlh
Follower
Plex server failing. Nighthawk R9000
I have been using the R9000 Nighthawk X10 Plex server for over 12 months.
It recently stopped working.
It was not working on Router Firmware Version V1.0.4.28 and I noticed that Router Firmware Version V1.0.4.34 upgrade was available.
I performed the upgrade hoping to fix the issue, but it did not.
When I go to the Plex Media server page there is a new button to Rebuild Database Your Plex database encountered issues. To fix the issues, click the Rebuild Database button.
This has not fixed the issue.
I have tried the disable and enable check box.
No success.
When I attempt to go to the http://routerlogin.net/plex page...... I get This site can't be reached.
Any suggestions???
Thank You!
Alanlh
Model: R9000|Nighthawk X10 AD7200 Smart WiFi Router
Message 1 of 2
Guru
Re: Plex server failing. Nighthawk R9000
I've never used the R9000 but if something got corrupted, a factory reset is a good place to start. If it truly was corrupt, I'd reinstall the firmware over a hardwired connection, then reset it, and manually redo your setup. Its a bit of a scorched earth plan but it makes sure one of your settings or backups isn't causing the issue.
https://www.netgear.com/support/product/R9000.aspx
CM2000-> RAX200-> GS716v2-> EX8000
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 344 views
  • 0 kudos
  • 2 in conversation
Announcements
