Orbi WiFi 7 RBE973
PoE Network Switch?
airj1012
Tutor
PoE Network Switch?
I have a panel containing all my ethernet runs to my entire house. I'm going to add a network switch to this panel to facilitate the internet getting to all the rooms. There is not a plug within the panel, although there is one below it. However, I'd like to use a PoE system to avoid having to plug that network switch into an AC plug. Is this possible? Do I need a PoE network switch upstream from the network switch that would be in the panel?
Modem -> Network Switch (PoE) -> Network Switch (Non-PoE)
Would that work? Thanks.
Message 1 of 3
Accepted Solutions
Guru
Re: PoE Network Switch?
Message 2 of 3
All Replies
Guru
You might get better results in the switches forum.
https://community.netgear.com/t5/Switches/ct-p/business-switches
Message 2 of 3
airj1012
Tutor
Thanks, I couldn't find a switches sub. Will delete this thread.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 700 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
