Reply
Poor connection on 2.4 Gz but 5 works fine
jackier
Having problems with poor signal stregnth on 2.4 Gz even though computer onloy about 5 feet from router and 5 Gz is fine.  Also having poor speed on 2.4 Gz.  Tried rebooting as well as firmware upgrade with no results.
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 4
IrvSp
Master
Re: Poor connection on 2.4 Gz but 5 works fine
What is the make and model of the computer? Since this is a 2.4Ghz connection, that would make the PC kind of old? Newer ones are dual-band usually. If this is a laptop and the antennea is inside the case that could cause weak signal.
Poor signal = Poor speed, especially if a lot of retries for TCP/IP is needed.
Some solid data here would help. ISP speed, and what do you get on the 2 wireless SSID's and a wired connection? Is QoS or Traffic Meter enabled?
Did it ever work OK?
Message 2 of 4
jackier
Hi
Thank you for your fast reply
Not sure the computer matters.   Have a dual wireless router that has 2.4 and 5 modes.   Have problems on desktop computer as well as laptop, iphones and ipad.
Have used speedtest.  Not sure what the other items are that you are asking about
Message 3 of 4
IrvSp
Master
@jackier wrote:
Hi
Your original post:
You didn't answer with any details. Assuming the computer is using wireless you gave the same non-data answer.
Yes, since now you've detailed more devices assumed to be on the 2.4Ghz band, but I got no data from you to go on?
I asked:
All I got back was you used speedtest but not a single number or if it ever worked?
Can you tell me the various speeds you are seeing and what the ISP provided speed it?
I'll ask again:
  • Did it every work at full speed (OK)?
  • Is QoS enabled?
  • Is Traffic Meter enabled?
  • What is the speed you see on the 2.4Ghz SSID?
  • What is the speed you see on the 5Ghz SSID?
  • What is the ISP provided speed?
New question, have you tried changing the 2.4Ghz channel number (assuming it is set on Auto)?
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 371 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
