Reply
Port Forwarding not working
Xboxgamer1998
Follower
It won't let me chose the option to Port forward and I cannot figure out why. Under the advanced setup, it doesn't let click the "Port Forwarding / Port Triggering" tab. I would like to use this to set up a static IP address with my Xbox to fix my NAT type. please help
Model: R7300DST|Nighthawk DST—AC1900 DST Router
Message 1 of 2
antinode
Guru
Re: Port Forwarding not working
> It won't let me chose the option to Port forward [...]
   Does it threaten you with GBH, or what?
> [...] Under the advanced setup, it doesn't let click the "Port
> Forwarding / Port Triggering" tab. [...]
   Do you mean that the control is "grayed out"?  To what is the
R7300DST connected, some other router?  Is the R7300DST configured as a
wireless access point?
      https://kb.netgear.com/26765/
      The following router features are not available (grayed out) when
      the router is in AP mode:
         o Port Forwarding/Port Triggering
> [...] I would like to use this to set up a static IP address with my
> Xbox to fix my NAT type. [...]
   If there's another router between your ISP and the R7300DST, then all
that stuff probably should be done on that outer router.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 369 views
  • 0 kudos
  • 2 in conversation
Announcements
