Orbi WiFi 7 RBE973
Reply
Port forwarding on r8000 not working
4IDp8
I am trying to open port 25565, but it when i use https://www.canyouseeme.org it says timed out
I am trying to make a minecraft server
I know little about port forwarding
Spoiler
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 14
Accepted Solutions
antinode
Guru
Re: Port forwarding on r8000 not working
> >I have tried port forwarding inside of the main router using the
> "88.90.##.## address, but it don't seem to work
   What was the actual port-forwarding rule there?
>     >Even if the server is up and running while I test it, it says:
> "Connection timed out"
   It won't work is the server is not on the LAN subnet of the main
router.
> IPv4 Address. . . . . . . . . . . : 10.0.0.37
   An R8000 would do that if it's configured as a router, and its
WAN/Internet port is connected to another router which is using
"192.168.1.*" for its LAN.
> How do I configure it like you said?
>    Visit http://netgear.com/support , put in your model number, and look
> for Documentation.  Get the User Manual.  Read.  Look for "Use the
> Router as a Wireless Access Point". [...]
> DHCP is enabled:
   The change to WAP mode will stop that.
> Here is the main menu, tell me what you want me to click on and I will
> copy the information and reply with it
   Too much work.  I'd guess that Address Reservation would be under
"DHCP" or "LAN hosts".  I'd look for port forwarding under "Port
forwarding".
> I don't wanna mess up my parents WIFI or stuff tho
   Adding an address reservation or a port-forwarding rule should be
pretty safe.  But, safe or not, the main router needs to do the port
forwarding.
> Your friends use your (one, only) public IP address ("88.90.##.##")
> to talk to your main router -- the router which is connected to your
> ISP. [...]
So, the main router must do the port forwarding.
   And the server must be on the main-router LAN subnet.  So, directly
connected to the main router, or else connected to the R8000 when the
R8000 is configured as a WAP.
Message 13 of 14
All Replies
antinode
Guru
> I am trying to open port 25565, [...]
   In my experience, people who talk about ports being "open" or
"closed" often don't understand the problem.
   Is your server running?
   For the usual problems with port forwarding, see:
      https://community.netgear.com/t5/x/x/m-p/1859106
   In-line images must be approved by a moderator before others can see
them.  The time required varies.  Attachments have no such limitation.
Of course, attachments have their own one-per-message limitation.
   In a thousand words or less, what's your picture supposed to show?
Copy+paste is your friend.
Message 2 of 14
4IDp8
>>What do you mean by that? I am trying to make it so people outside of my network can connect to the server on 25565.
>>Yes, i have tried with the server both on and off
>>I am 13
   In a thousand words or less, what's your picture supposed to show?Copy+paste is your friend
>>An image of my screen while adding a new port
Message 3 of 14
antinode
Guru
   That's fine, but whether it involves "opening" anything is a
different question.
> >>I am 13
   That's ok, too.
   Have you gone through those steps/tests?
   Not a big improvement over the hidden picture.  While we're waiting,
go through that previously cited thread.
Message 4 of 14
4IDp8
I copied this from the lik you gave me.
> Model: r8000
   Is that accurate?  Firmware version?
>V1.0.4.62_10.1.74
   1. Wrong external IP address (different from the port-forwarding
router's WAN/Internet IP address).  (An intermediate NAT router, for
example, could cause this.  Or an ISP using carrier-grade NAT to
conserve IPv4 addresses.)
   Does the IP address of the WAN/Internet interface of your router
match what you're using as your public IP address from the outside
world?  ADVANCED > ADVANCED Home : Internet Port : Internet IP Address
>IP Address 10.0.#.##
My public IP: 88.90.##.##
Connection DHCP
IP Subnet Mask 255.255.###.#
Domain Name Server 148.122.##.###
148.122.###.###
   2. Bad port-forwarding rule (wrong port(s), wrong target address --
including a wandering target).
   I can't see your actual port-forwarding rules.  Copy+paste is your
friend.
>I just copied this:
Service Name
Minecraft server
Protocol
TCP/UDP
External Port Range
25565
(1~65534)
(Specify ports and/or port ranges spilit by commas, example: 30, 50-60, 65500-65510)
Use the same port range for Internal port
Internal Port Range
25565
(1~65534)
Internal IP address
192
168
Or select from currently attached devices
   How did you ensure that your (unspecified) "a server for a game"
system always has the right IP address?  Static configuration?  Reserved
dynamic address?
   3. Server not listening on the port-forwarding target system.
   Can you access the server from a system on your LAN using the
server's LAN IP address?  If you can't access the server locally, then
there may be little chance of doing it from the outside world.
>I CAN acces the server from the same network
   If that works, then, still from a system on your LAN, try using the
router's WAN/Internet IP address.  That should verify the
port-forwarding rule(s) (and the "NAT loopback" feature of the router).
>How do i find that?
   4. External influences: ISP blocking, other firewalls, ...
>I have tried disabling my firewall from windows settings, but that seems to not be working, i have also whitelisted port 25565
   Seldom the problem.
> [...] and it doesn't work, because other people can't connect
   "doesn't work" or "can't" is not a useful problem description.  It
does not say what you did.  It does not say what happened when you did
it.  As usual, showing actual actions (commands) with their actual
results (error messages, LED indicators, ...) can be more helpful than
vague descriptions or interpretations.
End of the copy
I answered some of the questions as good as i could, hope it helps
Message 5 of 14
4IDp8
I have also thought about factory reset
But the network belongs to my parents
And, I am afraid to mess something up, like for example: Deleting the guest network, Deleting the 5ghz Guest network, or Deleting the 5Ghz Network
Does the factory reset delete any of these? Or is it safe?
Message 6 of 14
antinode
Guru
> [...] ADVANCED > ADVANCED Home : Internet Port : Internet IP Address
   That's looks like a problem.  Is the R8000 (WAN/Internet port)
connected to some other NAT router? _That_ would be the router where
you'd need to do the port forwarding.  (That's the _first_ "usual
problem for a reason.)
   To what, exactly, is the R8000 connected?
   If another router is connected to your ISP (and _its_ WAN/Internet
IP address is that "88.90.##.##"), then you might want to configure the
R8000 as a wireless access point, not as a full-function router.
   (That public IP address ("88.90.##.##") is the only thing which you
should be hiding.  Any "10.x.y.z" or "192.168.y.z" address, or your
subnet mask ("255.255.255.0", presumably) are of no use to anyone.)
> dynamic address?
   That's still a question, but, again, it would involve the main
router (with the public IP address), not the R8000.
   I doubt that a settings reset would help.  It _would_ reset all the
wireless-network SSIDs, and all other settings.
Message 7 of 14
4IDp8
We are using a thingy from the Norwegian company "Telenor" I HAVE port forwarded there, but it is quite complicated.
So, the "Telenor" router gives of lot of LAN cables witch feed into the r8000 router and other LAN/ethernet connections in my house
I just copied the format(Filled out)
Minecraft server tcp/udp: 25565, 192.168.1.##
/Name
"Minecraft server"
/Choose a descriptive name.
/Protocol
"TCP/UDP"
/LAN IP
"192.168.1.##"
>>I think the problem up here, there is so many LAN/WAN and public and other IPs, i dont know whitch one to connect to
/IP address of the LAN host.
/WAN port start
"25565"
/WAN port end
"25565"
/LAN port start
25565
/LAN port end
"25565"
/End port gets calculated.
Message 8 of 14
4IDp8
> >IP Address 10.0.0.37
>Another "router, or something like that" that gives of many Ethernet/LAN cables through our house
>>Wdym?
> dynamic address?
>>I don't know how to find
Im sorry, iu dont know much about this, i just wanted to play Minecraft with my friends from my own computer
Message 9 of 14
antinode
Guru
> We are using a thingy from the Norwegian company "Telenor" [...]
   As a description, the maker and model number would be more helpful.
   If your ISP connection goes to that router, so that _its_ WAN IP
address is "88.90.##.##", then _that_ is where you need to do the port
forwarding.  Your friends in the outside world will be talking to that
router.
   And devices which are connected to your "a thingy" get (LAN) IP
addresses in the "192.168.1.*" subnet?
> [...] the "Telenor" router gives of lot of LAN cables witch feed into
> the r8000 router [...]
   Why do you have the R8000?  Are you using the R8000 to improve your
wireless network coverage?  If so, then it might be a good idea to
configure the R8000 as a wireless access point, not as a full-function
router.  That would put _all_ your client devices, including your
Minecraft server system, on the "192.168.1.*" subnet, and that should
let port forwarding on your "a thingy" work properly.
   Don't hide any of the "192.168.1.z" addresses.  What's the (LAN) IP
address of your Minecraft server system?
   You need to know.  A port-forwarding rule includes the address of the
server.  If your Minecraft server uses DHCP to get its IP address from
the (DHCP server in the) router, then it could get a different address
every time it (or the router) restarts.  But the server's address must
be the address in the port-forwarding rule.
   On a Netgear router, you can reserve an address for the server at:
ADVANCED > Setup > LAN Setup : Address Reservation.  I assume that it's
also possible to do that on your "a thingy" router, but I know very
little about it.  (Note that this is the _second_ "usual problem".)
> [...] i just wanted to play Minecraft with my friends from my own
> computer
   Sounds simple, doesn't it?  Sadly, everything's complicated.
ISP.  When a friend tries to talk to port 25565 on your router, what
should the router do?  To which of the computers/devices on your LAN
should it send that message?
   A port-forwarding rule tells the router what to do.  That is, to
which (LAN) address it should send that message.  In this case, that
would be your Minecraft server.  But, of course, your Minecraft server
must _always_ be at the address in that rule, so you need to make sure
that your Minecraft server always gets the same address.  So, "Address
Reservation" (or whatever your main router calls it).
   It might be a good idea to connect your Minecraft server directly to
your main router, and see if you can get things to work properly without
involving the R8000.  If you can get that simpler system to work, then
adding the R8000 might be relatively easy.
Router as a Wireless Access Point".  With the R8000 configured as a WAP,
you should be able to add it between your main router and your Minecraft
server without adding any new problems.
   Isn't this educational?
Message 10 of 14
4IDp8
router.
   >I have tried port forwarding inside of the main router using the "88.90.##.## address, but it don't seem to work
    >Even if the server is up and running while I test it, it says: "Connection timed out"
I copied some information from "Lan hosts" this is my computer
Static DHCP
[  ] (Should i toggle)
Name for Computer
Desktop-[...]
IP address
10.0.0.37
MAC (ASUSTek)#############
ConnectedEthernet/2
Rate100M/full
Signal-
Uptime
Serial numberUnknown
Connected toRG
"Here is the information that comes up when I type ipconfig in cmd:
I replaced ipv6 and other stuff I don't know what is with [...]
Windows IP Configuration
Ethernet adapter VirtualBox Host-Only Network:
Connection-specific DNS Suffix . :
Link-local IPv6 Address . . . . . : [...]
IPv4 Address. . . . . . . . . . . : 192.168.56.1
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . :
Wireless LAN adapter Lokal connection* 10:
Media State . . . . . . . . . . . : Media disconnected
Wireless LAN adapter Lokal tilkobling* 11:
Ethernet adapter Ethernet 3:
IPv6 Address. . . . . . . . . . . : [...]
Temporary IPv6 Address. . . . . . : [...]
Default Gateway . . . . . . . . . : [...]
10.0.0.138
Wireless LAN adapter Wi-Fi 2:
IPv4 Address. . . . . . . . . . . : 192.168.1.10
Default Gateway . . . . . . . . . : 192.168.1.1
I think so
I believe the r8000 is for WIFI and the Main router(telenor) is for LAN (I am not sure)
> Minecraft server tcp/udp: 25565, 192.168.1.10
DHCP is enabled:
[ ] Enabled
Local IP network
10.0.0.138/24
First DHCP address
10.0.0.
1
Last DHCP address
10.0.0.
137
DHCP lease time
86400
Here is the main menu, tell me what you want me to click on and I will copy the information and reply with it
Telenor
TelenorMenu
Router administration
[X] Advanced mode
Wireless:
Wireless networks
Wireless radio
Wireless scan
LAN:
Parental control
LAN hosts
Network map
DHCP
UPnP
WAN:
Port forwarding
Firewall
DNS
Dynamic DNS
DMZ
WAN protokoll
Static routes
Actions:
Router information
Firmware upgrade
Ping
Reboot
Reset
LED
Bandwidth:
Bandwidth usage LAN
Bandwidth usage WAN
Contact customer support if you have any questions. Click here to give us any feedback about Router admin.
> computer
My PC uses both LAN and WIFI, I just bought a WIFI/bluetooth thing for 60$, because I thought it was nessesairly to port forward
Basicly, i thought i needed to use WIFI to port forward.
I will just turn off my WIFI receiver for a moment then, and just use ethernet
for Documentation.  Get the User Manu...
If you could add me on discord, or something, i could send you images, that would be easier
So just in case, here is my discord tag: 4IDp8#9057.
You choose if you wanna add me or not, no pressure.
Message 11 of 14
4IDp8
By the way, here is the "telenor router" information
Telenor
Overview
Menu
Router information
Basic information
Reference [something...]
IP address 88.90.##.## <--------[This one is the same as my public ipv4]
Serial number [Somethin else]
Model Zyxel 8702
Uptime 11d 22h 34m
Firmware upgrade
The router has software version 1.00(AAJX.14), which is the latest version available.
Message 12 of 14
antinode
Guru
router.
> DHCP is enabled:
forwarding".
forwarding.
> ISP. [...]
Message 13 of 14
4IDp8
I fixed the probolem, i took contact with the company Telenor, and they said i were using the wrong IP address for the port forwarding
It works fine now
Anyways, thank you so much fo taking the time to help me.
I really appreciate it!
Message 14 of 14
Top Contributors
Discussion stats
  • 13 replies
  • 5594 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
