Reply
Port forwarding on which router?
Janromero
 Just asking anyone if you had this problem before...
 I have three routers at home.  the main router is a Verizon Fios Quantum Gateway FiOS-G1100 Wireless Router. The second router is a Netgear R7000 and the third is another Netgear R7000. All connected via a CAT6 ethernet wire, one after the other.
 My question is on which router do i setup the port forwarding for my kid's PS4?
Model: R7000|AC1900 Smart WIFI Router
Message 1 of 8
Janromero
Re: Port forwarding on which router?
  p.s. the two R7000 are connected as Wireless Routers to the main router. The PS4 is also wired.
Message 2 of 8
Janromero
... all routers are wired through LAN to LAN.
Message 3 of 8
microchip8
Master
You're creating a triple NAT issue if all operate in Router mode. You should use one as router and the others as Access Points. If all are in router mode, you'll have to port forward on all of them. But the triple NAT is the real problem here
Routing: NETGEAR R7800 - Voxel Firmware 1.0.2.84SF
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (JGS516v2)
Desktop: AMD Ryzen 7 3700X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400 - Cruncher: Intel Core i5-7400
Message 4 of 8
antinode
Guru
> [...] on which router do i setup the port forwarding [...]
   Port forwarding would normally be configured on the router which is
connected to the ISP.  Which, as discussed elsewhere, should be your
only router.
      https://community.netgear.com/t5/x/x/m-p/1874287#M152194
   Any special configuration on the R7000 units?
   If I were trying to get the effect of configuring the two R7000 units
as wireless access points, then I'd probably do it by the book, rather
than use some ad-hoc scheme.
Message 5 of 8
antinode
Guru
   Not if:
Message 6 of 8
Janromero
   No special configurations on the two R7000. I just turned off their DHCP.
Message 7 of 8
antinode
Guru
> DHCP.
   I'd call that "special".  You didn't do it on your main router.
   Still true.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 319 views
  • 0 kudos
  • 3 in conversation
Announcements
