Reply
Port not opening for game server
Bub525
I have a active game server listening on a port, allowed through windows firewall and have the correct setup in the router for port forwarding. I've triple checked the PC's local IP and the one I'm forwarding to. I've triple checked my port I forwarded. No matter what I've tried, even DMZ, I can't get the port to listen to outside traffic.
I have a fiber Modem, that's giving my Router internet. I've tried getting into that modem's management but can't seem to find out how. I'm not sure the problem is through the modem or not.
I'm absolutely lost on what to try next or how to get any farther than I have been. The model on the router itself says RAX20, the modem is from ADTRAN, model number TA334. Couldn't find hardly any info on the modem.
I've used port checkers to see if the port was open and the game server won't show up or allow any connection. The service works because I'm able to play on LAN.
Model: RAX40|Nighthawk AX4 4-Stream WiFi Router
Message 1 of 4
Guru
Re: Port not opening for game server
What happens if you connect directly to the ADTRAN with your game server PC?
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode |  Wifi Router RBK953 (Router Mode) 2.5Gb Wired Backhaul | Switches NG GS105/8, GS308v3, GS110MX and XS505M XR1000 (Router Mode) RBK853 AP Mode  |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700
Message 2 of 4
Bub525
I haven't checked because if anything else such as my router is plugged in it won't give any network assignments to the PC. The PC is the only thing that can connect to the modem at one time. Having the router and the PC connected seperately causes the modem to not care about the PC and not give it any kind of network access. Im not sure this is my ISP's default normal equipment though. It's the modem that was setup on the fiber when I had moved in
Message 3 of 4
Bub525
I can't access any kind of GUI or anything when I try to access it like I do my router. Typing the gateway in does absolutely nothing
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 202 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
