Orbi WiFi 7 RBE973
Reply
Port wont open for my minecraft server
Gamer101
Im having issues with port forwarding my minecraft server to port 25565 i have the server open and i port forwaded both TCP and UDP and allowed everyhting through my firewall i ran the port check tool it keeps timing out on port 25565 i even tried to have a friend connect they could not connect at all and yes i made sure im using my computers ip address on the port forwarding.
Please help me!
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 12
Accepted Solutions
Gamer101
Re: Port wont open for my minecraft server
i fixed it was just my firewall blocking it
Message 12 of 12
All Replies
That's the second one this week.
It comes up pretty often.
Did you try this in your research:
Search - NETGEAR Communities – minecraft port forwarding
Message 2 of 12
Gamer101
Yes i did and some of them did not help at all
also i have a modem that is seperate from the netgear router
could there be any issue with the modem doing it?
Also should i use Address reservation?
Message 3 of 12
Possibly.
What is that modem?
Message 4 of 12
Gamer101
i have a technicolor modem
i am not sure if its causing the issue
Message 5 of 12
Sp, we know who made (or sold) tour modem. Sadly, we still don't know what model it is.
Without that information no one can begin to guess if your modem is just a modem or a modem/router.
A web search shows that Technicolor has produced many different devices over the years and quite a few of those are "gateways" which combine modem and router. Irf you have one of those it will almost certainly get in the way of what you are trying to do.
Most bits of kit have a label on them that says what it is, its modem number. Look on the back of yours.
Message 6 of 12
Gamer101
I took a look at the back of the medom and i found the modems model number
model number is TC4400-AM
Message 7 of 12
Excellent. Thanks for that.
Unfortunately, it is hard to find anything definitive, so it isn't obvious (from Google) if this is also a router. It says it has two LAN ports in the back, which smells like a router, although it maybe something called "bonded channels", two lines into a router that supports this to get faster Internet.
Other people have also been puzzled by this in the past.
We can't rule out that it is a modem/router, although it doesn't look like one.
Sorry, but that doesn't get us much further.
Message 8 of 12
Gamer101
Thank you ill try to log into the modem and see if there is anything causing a issue
Message 9 of 12
Gamer101
I logged into the modem nothing seems to be causing a issue
on the router when i logged in to it im not sure if some of these things could be causing a issue
i did look at the logs and when i go to log into my server the router detects the ports working but, im not sure if something is blocking a connection coming back.
Could these be a cause??
Use router as DHCP server?
address reservation?
also could it be something in the WAN setup??
Message 10 of 12
Gamer101
I just looked over the routers settings could both these be any sort of issue
i currently hes thses seting set for the DNS and internal ip address on the router
Get Automatically from ISP for DNS
Get Dynamically from ISP for the internal ip
should i be using a static ip?
Message 11 of 12
Gamer101
Message 12 of 12
Top Contributors
Discussion stats
  • 11 replies
  • 3643 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
