Reply
Portforwarding Nighthawk R6
peteralm
Hello,
I have got a R8000 Router and want to do portforwarding.
I wanted to just make it like in my TPLink router.
Because in the past i had more servers to logon to i used more ports.
But now i have only 1 server were everything is integrated to.
In my TP Link i could forward more external ports to 1 internal port on 1 ipadres.
Now the Netgear doesn't let me do that and comes with the messege that there is a conflict.
How can i solve this?
Model: R8000|Nighthawk X6 AC3200 Smart WIFI Router
Message 1 of 10
schumaku
Guru
Re: Portforwarding Nighthawk R6
Welcome to the Netgear Community Forum!
@peteralm wrote:
Hello,
Somehting like 80/TCP, 81/TCP, 82/TCP, 83/TCP -> one LAN IP, 80/TCP for example?
Not sure why you want tho do that. In a strict NAT config, it's more than just a little bit strange. Best guess you don't want to change any configuration out there. I don't think this is possible.
-Kurt
Message 2 of 10
peteralm
Hello Kurt.
Well normal onze port will do it but in de past in had more servers on more poets with users who could log into this.
After Someren time i integrated this tot one server with one port.
In all my routers i had i could this.
This is my first router what can not do this.
So the cheaper routers are smarter then this one.
Thanks for the comment.
I will look if another brand van do this and i will change over then if i can not make this running.
Message 3 of 10
peteralm
Sorry. Some words are changed automatic to dutch by my phone. This is irritating Smiley Happy.
I hope you understand.
Message 4 of 10
JamesGL
Master
Hi peteralm,
In port forwarding, you can configure the external port to use different port numbers and use the needed port number for Internal port.
Message 5 of 10
schumaku
Guru
@JamesGL, in my understanding @peteralm is looking for an overloaded NAT with multiple ports on the WAN/I ternet interface NATed to a single LAN IP and port, ie. 75..85/TCP  to 80/TCP.
Message 6 of 10
peteralm
@schumaku,. That is correct. I know how portforwarding workshop. But i cannot forwar multiple external ports to one internal ports.
This I could with my old TPLink.
Message 7 of 10
peteralm
Pfff stupid phone. Workshop means works
Message 8 of 10
storm1985
Prodigy
Message 9 of 10
schumaku
Guru
Multiple ports to one port on the same LAN IP is requested - not possible as per the referenced post.
"(2 or more) external ports - (1) internal port - (2 or more) IP address (this should work)
(2 or more) external ports - (1) internal port - (single) IP address (NO!!!)"
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 1800 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
