Orbi WiFi 7 RBE973
Reply
Ports won't open. RAX45
McFunk
Follower
Hi all. I am trying to do port forwarding on my new router. The router we took out had this port forwarded and was letting the traffic in but was restarting constantly so we had to replace it. I went into port forwarding and clicked "add custom service", entered the port number, internal address Ip and clicked apply.  The fowarding now shows in the table on the port forwarding page but when i check to see if its open on a port checking website it says its closed. Can anyone help me figure out what i'm doing wrong?
1TCP/UDPTCP/UDP2011201120112011192.168.100.200
Message 1 of 3
Accepted Solutions
Guru
Re: Ports won't open. RAX45
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wif...
Be sure to include your ISP modem brand and model#.
Check the user manual for the router for information regarding Port Forwarding information.
Thank you.
Message 2 of 3
All Replies
Guru
Thank you.
Message 2 of 3
Guru
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1119 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
