Reply
Power Adapter for Nighthawk x10 r9000 Netgear
Kofi1
Follower
My R9000 was imported from the US to Ghana where it will be used. However, the power specs on the adapter is :
Input; 100-120V ~50/60Hz 1.5A.
Output: 19V == 3.16A
Meanwhile, power supply for electronic devices in Ghana is 220-240v.
Is it appropriate or possible to use my r9000 with the above power specs on the 220-240v in Ghana?
Kindly help me out.
I need to use my device.
Message 1 of 2
Guru
Re: Power Adapter for Nighthawk x10 r9000 Netgear
No.
But you can get a 22v to 120v power adapter to convert the power.
Or you can get a 3rd party power supply that supports a  19v / 3.16amp power output.
(I've heard some of the orbi power supplies support both 120/220 but I haven't heard anything about this model)
Current Setup: CM2000-> SXK30-> GS716v2-> Arris W31 x2-> Pi-hole->
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 55 views
  • 0 kudos
  • 2 in conversation
Announcements
