Orbi WiFi 7 RBE973
Reply
Power LED is blinking R7800
mjeeda
Hi, today i update my router R7800 from app on iphone
after that my router is Power LED Is Blinking and no wifi
i was on version 10.0.2.36
Thank you.
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 15
Accepted Solutions
avtella
Prodigy
Re: Power LED is blinking R7800
No it should be something like this: tftp -i 192.168.1.1 PUT nameoffirmware.img
If you wanna make things simple just rename the file to like a.img so its easier to type or paste in the command prompt.
Message 13 of 15
All Replies
TorkilH
Got the same problem. 😞
Message 2 of 15
Guru
Try a Factory reset on the router and setup from scratch...
Message 3 of 15
avtella
Prodigy
You may need to do a tftp flash with the latest firmware or older one if you want. I posted detailed instructions on how but the forum decided it needs to be moderated for some reason.
Just follow these instructions:
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/SOLVED-Steps-for-debrick-unresponsive-R7000-...
Message 4 of 15
Guru
Theres this FAQ:
https://kb.netgear.com/22688/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP
Hopefully a factory reset is all thats needed.
Message 5 of 15
avtella
Prodigy
Hopefully, but as for that tftp app its never worked for me. I've always done it directly via prompt.
Message 6 of 15
Guru
Ya I asked if NG would update that FAQ. Needs updating.
Message 7 of 15
mjeeda
Message 8 of 15
JamesGL
Master
Hi mjeeda,
Did it work for you?
Message 9 of 15
mjeeda
No
Message 10 of 15
JamesGL
Master
Hi mjeeda,
Have you tried the TFTP using the software?
Message 11 of 15
boby7
I don't want to be too smart, I am new here but...
Do You think that tftp syntax on the attached by mjeeda screen is ok?
Message 12 of 15
avtella
Prodigy
Message 13 of 15
antinode
Guru
   Apparently not, or else the TFTP program wouldn't have emitted that
usage guide.
   As usual, copy+paste of plain text would have been more helpful than
a picture of plain text, but, as I read it, the attempted command was:
      tftp -192.168.1.1 putR7800-V1.0.2.46
which is missing the "i" in "-i", is missing required white-space to
separate the tokens (twice), and (most likely) specifies the wrong file
name.  ("Apart from that, Mrs. Lincoln, how did you enjoy the play?")
   Something like the following might have had a better chance:
      tftp -i 192.168.1.1 put R7800-V1.0.2.46.img
   See also:
      https://community.netgear.com/t5/x/x/m-p/1533866#M87578
Message 14 of 15
avtella
Prodigy
antinode its the latter one with -i that works. I use it quite often for testing various firmwares of LEDE/OpenWRT and returning to stock, been the same way since my WNDR3800 infact. Doesn't work without -i not to mention he forgot to put a space between put and the filename like you mentioned plus the file extension as well.
Message 15 of 15
Top Contributors
Discussion stats
  • 14 replies
  • 5546 views
  • 1 kudo
  • 7 in conversation
Announcements
Orbi WiFi 7
