Reply
Highlighted
Power Light Flashing Green
The power light keeps flashing green. Holding reset does nothing and the app won’t find the router. What can I do to get access to the router again?
Model: R6080|AC1000 Dual Band WiFi Router
Message 1 of 4
Highlighted
Guru
Re: Power Light Flashing Green
> The power light keeps flashing green. [...]
   You may be a candidate for the TFTP recovery scheme.  See, for
example:
      https://community.netgear.com/t5/x/x/m-p/1622096#M102004
   Any triggering event like, say, a firmware update, or EMP from a
nuclear attack?
Message 2 of 4
Highlighted
Our internet was messed up. But we thought it was fixed. Tried to update firmware but then internet connection was lost. Now it just blinks a green light on the power button. What are the best steps to take to fix this?
Message 3 of 4
Highlighted
NETGEAR Moderator
You can try to hold the reset button for 30 seconds to see if the router resets. If that does not work you can try and recover the router using the TFTP method that I linked below.
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
DarrenM
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 350 views
  • 0 kudos
  • 3 in conversation
Announcements
