Reply
Powerline NetGear 1200 slow
ChuongNg
Follower
I just upgrade speed of my internet from 75 to 100mbps, but I dont know how I put the powerline netgear 1200 to my desktop the max speed always 45mbps, but the app speedtest in my iPhone always 105mbps. Is that problem to my netgear1200?
Message 1 of 3
Guru
Re: Powerline NetGear 1200 slow
so your iphone over wireless gets 105mbps.
the desktop connected via powerline gets 45mbps.
Powerline is sensitive to interference within the wiring. That could be why the powerline is slower. Things like gfci outlets, surge protectors, arc fault breakers, high draw motors, cheap cell phone chargers, can all influence powerline interference/speeds.
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 3
labatt
Mentor
Ethernet over power adaptors are not all created equal. They come in different speeds, so the 45 you are getting maybe as good as it gets with the adaptors you have.
Modem CM2050V
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 287 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
