Discussion stats
  • 1 reply
  • 112 views
  • 0 kudos
  • 2 in conversation
Announcements
Top Contributors
Reply
Highlighted
Follower
Private network setup.
How do I set-up this router as a private netwotrk (no internet) to route music from a MAC (early) to network a/v reciever?
I would prefer to hardwire the network.
Model: R6220|AC1200 Smart WiFi Router with External Antennas
Message 1 of 2
Highlighted
Prodigy
Re: Private network setup.
Sounds like you are just wanting to use the switch and DHCP portion of the router. Easy to do. Just plug devices into the Ethernet ports and they will get an IP address from the router. Turn off wireless, either in the GUI or switch, and you should have connectivity. Have done this. You my see a warning about no Internet connection.
If you set an IP address on each device then you would use a dumb switch.
Modem CM1150V
Message 2 of 2
