electric58
Nov 10, 2017Follower
Problem connecting PS4 via ethernet to R8000
Preliminary Info: Purchased router approx. 2 years prior. Installed perfectly with no issues. Decided to purchase and install NetDuma router. Set R8000 as an AP. I am now trying to remove NetDuma and install R8000 as router.
Powered up R8000 and rest to factory default by pressing rest button until the router rebooted. Installed genie. During setup "use as router" was selected. WiFi works perfectly. Laptop connects via WiFi and ethernet. PS4 will not connect with WiFi or ethernet. Genie does not have tab for advanced setup for port forwarding or other features. When attempting to connect via 192.168.1.1 receive meassage pop-up "can not connect to page." Details indicate that ethernet connection is not available. Network on laptop indicates ethernet is connected via RealTek broadband ethernet card. I'm thinking the R8000 must still retain some AP setting but I can not access to determine if this is true. Any suggestions?
Hi electric58,
Try to reset the router to factory default again. Access 192.168.1.1 or routerlogin.net instead of the Genie app when configuring.
- JamesGLNETGEAR Employee Retired
Hi electric58,
Hi electric58,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
