Reply
Problems with R6700v2 Wi-Fi connection with iMac
smg1981
Follower
I have been having problems with my router disconnecting and not reconnecting from my iMac. Additionally, it won't connect to the router's 5G network at all. I believe this is an iMac/Apple problem, because all of my other devices (including an older iMac) have no problem. However, Apple says I need to contact the router manufacturer.
Has anyone else experienced this sort of problem with an iMac? Let me know if you need further details.
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Problems with R6700v2 Wi-Fi connection with iMac
Have you tried to change the wireless channel on the router? also you could try to change the SSID or the password see if that will get the Mac to connect.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 300 views
  • 0 kudos
  • 2 in conversation
Announcements
