Reply
QOS Stopped workong AC1900 R7000
BigPartyPanda
My Qos no longer works.... It says QOS not supported but it was working when I got it only a few month ago.... please help? When I go into genie the internet tab and parental controls tab under the basic menu are both greyed out so I can't select these....
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 2
shamarin
Virtuoso
Re: QOS Stopped workong AC1900 R7000
What firmware version do you use? Do you try to go to advansed tab?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 257 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
