Reply
QOS on my R7800 is dysfunctional!!
mkvans
I don't understand why this is happening, but the QOS on my R7800 is acting wierd.  When the Dynamic QOS is enabled, it overrides a manually set Device Priority.  I have a ReadyNAS that is used as a Plex server and I have manually set the Device Priority to Highest a dozen times, but it keeps getting switched back to Low!!  If you manually set a Device Priority, it shouldn't be overridden by QOS!  Is disabling the Dynamic QOS the only way to fix this?  Thanks!
Model: R7800|Nighthawk X4S AC2600 Wifi Router
Message 1 of 8
LeeH
Prodigy
Re: QOS on my R7800 is dysfunctional!!
What speed is your Internet connection?  QOS will slow everything down unless you have limited bandwidth like 10Mbps.
Message 2 of 8
mkvans
My internet is 100Mbps/20Mbps.
Message 3 of 8
LeeH
Prodigy
With QOS turned off does running http://www.speedtest.net/ give you your full 100Mbps?
Message 4 of 8
mkvans
Yeah, it tested at 138Mbps/28Mbps.
Message 5 of 8
LeeH
Prodigy
It sounds like it is running great.  Do you have the NAS throughput you are looking for?
Message 6 of 8
mkvans
Only when the Device Priority stays at Highest. QOS keeps resetting it to Low though.
Message 7 of 8
LeeH
Prodigy
I thought QOS was turned off.
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 2711 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
