Reply
QoS reduces LAN speed R7000p
I am having an issue with QoS. I have a generally slow internet plan due to location. It is DSL with 10 down 1 up. Given the slow speeds I use QoS since there are two of us in the house with multiple devices. I have my priorities set correctly and it works fine over wifi. However, when I hardwired my PS4 to the router via cat6 ethernet cord, the speed slows to a crawl at around 800 kbps which is less than 1/10th of my download speed. This happens with the PS4 set to the highest priority.
I tested by plugging in the same ethernet cord to a laptop, and I am able to achieve the proper speeds. I even tested PS4 speed using wifi and I can achieve the proper speeds. I have disabled QoS for now in order to get the full bandwidth on the PS4 but given all of our devices in the house, at some point I will have to re enable it.
The router is on the latest stock firmware which is 1.3.1.64.
Does anybody have an ideas on how to fix it?
Model: R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 1
Top Contributors
Discussion stats
  • 0 replies
  • 238 views
  • 0 kudos
  • 1 in conversation
Announcements
