Orbi WiFi 7 RBE973
Reply
QoS
timsalas14
Follower
QoS
I have just purchased a Netgear Nighthawk r700.
Is there a way to do QOS based on IP on this thing? I ran into my xfinity 1 tb limit by streaming 4k, so I want to limit my tv's for example to 15mbit or something similar, i switched the connection to my 2.4 ghz band and limited that to 54 mbit, at least now the HD conntent doesnt show on netflix etc, but I want to slow down based on MAC address/IP is there an alternative firmware from netgear i can buy  that would give extra options?
Thanks,
Tim Salas
Message 1 of 4
Accepted Solutions
JamesGL
Master
Re: QoS
Hi,
You can only change the priority(low,medium,high) per device. It does support per MAC address/IP and specific bandwidth per device.
http://kb.netgear.com/25598/How-do-I-configure-the-Dynamic-QoS-feature-on-my-Nighthawk-router
Message 2 of 4
All Replies
JamesGL
Master
Re: QoS
Hi,
Message 2 of 4
JamesGL
Master
Re: QoS
Hi timsalas14,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Message 3 of 4
chascent
Luminary
Re: QoS
This is the firmware you need DDWRT:
http://desipro.de/ddwrt/K3-AC-Arm/
CC
Model: R8500|Nighthawk X8 Tri-Band AC5300 WiFi Router
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3225 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
