Reply
Qos for security cameras
beepsilver
Onlooker
Do I use upstream or downstream qos for power over ethernet (POE) ip security cameras? If you can, will you explain why? Thanks.
Message 1 of 5
fordem
Mentor
Re: Qos for security cameras
I've never used either, and never had any issues.
Give a man a fish, feed him for a day
Teach a man to fish, feed him for life.
Message 2 of 5
VE6CGX
Master
Hi,
Me neither. Cameras just work fine on WiFi. All my cameras are HD ones.
Message 3 of 5
jsaelman
On the R7000 QoS prioritises traffic based on either the type of traffic or the device you're sending the traffic to / from.
If you want a device to have a high priority in receiving data you choose the download QoS and for priority on sending data you use upstream.
So if your question is about saving data from your cam onto a disk, you use upstream.
If your question is about showing the cam stream without interrupts on a screen, you choose downstream QoS with the screen as priority device.
Message 4 of 5
beepsilver
Onlooker
Jsaelman, thank you--that was a great explanation!
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 3355 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
