Reply
Question about 1.0.7.6 Frimware for R7000
Ryan5091
Follower
Hey all, first time posting, and have a quick question.
I currently have both my routers running FW V1.0.5.70_1.1.91, as I had issues with the then current 1.0.7.2 even after doing a factory reset.
As I'm in a heavy network usage household, and the latest security issue is a concern to me, is there any known issues with the latest firmware or anything reported breaking or acting strange?
Thanks for any replies.
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 3
HiSpeed
Guide
Re: Question about 1.0.7.6 Frimware for R7000
Hi,
Due to the security problem fixed by the new release, I think your best bet is to install it and test it.
I've replaced my old 1.0.4.18 without reset, and everything appears good... til now...
● Netgear R7000 (Root Router)
● TP-Link Archer C7 v2 (WDS Bridge)
Message 2 of 3
Just in case you haven't seen it:
Security Advisory for VU 582384, PSV-2016-0245 | Answer | NETGEAR Support
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1856 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
