Reply
Question - connect to WAN over 5ghz WIFI and running a VPN?
Damien001
Follower
Hi all, wondering if it possible to use a r7000p to connect to another WIFI point over 5ghz(using it as a WAN connection) wifi, while running a VPN client(connecting to a remote VPN) and then sharing the connection over the local network of the 2.4ghz wifi and the plan ports.
Many Thanks
D
Model: Dual Band, R7000P|Nighthawk AC2300 Smart WiFi Dual Band Gigabit Router
Message 1 of 1
Discussion stats
  • 0 replies
  • 40 views
  • 0 kudos
  • 1 in conversation
Announcements
