Orbi WiFi 7 RBE973
Reply
Quick VPN question - hard drive size
goldenflash81
I'm a newbie when it comes to setting up a VPN. The step by step instructions on setting up a VPN on the r6700 mention a USB hard drive attached to the router. How big does the drive have to be? Is 1 TB big enough?
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 3
Accepted Solutions
schumaku
Guru
Re: Quick VPN question - hard drive size
Not sure where you might have seen this requirement. Nothing the like ie. here How do I use the VPN service on my Nighthawk router with my Windows client?
Message 2 of 3
All Replies
schumaku
Guru
Message 2 of 3
goldenflash81
I must have been reading another description, because I don't see any mention of it on the link you posted. Thanks!
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2886 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
