× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Récepteur Netgear EX7700
Sora35-
Follower
Hello, I will support to know if it is necessary to connect in ethernet cable the Netgear receiver either to the Netgear router or to the internet box?
Model: EX7700|AC2200 Nighthawk X6 Tri-Band WiFi Mesh Extender
Message 1 of 2
Guru
Re: Récepteur Netgear EX7700
The EX7700 is an access point or an extender.
If hardwired into another router (whether that be netgear or another manufacturer) then you'd hardwire it int.
If ran in extender mode, you'd connect it via wireless to another router.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 264 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
