Reply
R 8300 Firmware update
molson2
Follower
I tried many times to update firmware, it always failed. I need help. I have tried some fix’s on forum, to no avail
Message 1 of 4
Guru
Re: R 8300 Firmware update
What browser are you using?
Wired or wireless when updateing FW?
Be sure your unpacking .zip files if you manually download the files from NG download site.
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CM2000 Modem | Wifi Router RAXE50 and R8500(v.158) Router Mode and RBK752(v.2) AP mode | Switches NG GS105/8 |
Additional NG HW: C7800/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
Message 2 of 4
Guru
How are you attempting the update?
what process are you using?
Where is it failing in the process?
Have you tried manually updating/
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
Current setup: CAX80->Trendnet TEG-S380->GS716T-> RBK752->pi-hole
1.4gig download/50mbps upload
We’re members of the public helping out on our own time.
Message 3 of 4
There was no answer the last time someone asked @molson2 those questions:
Will not update. Never has updated. V1. 0 2.86_1.0... - NETGEAR Communities
Maybe they were, quite understandably, put off by the response they received there.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 152 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
