Reply
R6020
DNMO
R6020
I tried factory resetting based off it just all of a sudden stopped connecting . It worked then just the power button started flashing out of no where. I tried resetting again but it will not take. Any other options ?
Model: A6200|802.11ac Dual Band WiFi USB Adapter
Message 1 of 3
DNMO
Re: R6020
R6020 Dual Band
Message 2 of 3
antinode
Guru
Re: R6020
> [...] just the power button started flashing [...]
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual.  Look for "Power LED Is Off or
Blinking".
   You may be a candidate for the TFTP recovery scheme.  See, for
example:
      https://community.netgear.com/t5/x/x/m-p/1622096
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 322 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
