Reply
R6080 router doesn't do 300 megs
dickgee
Follower
Netgear says R6080 specs can do 300 megs. My new one won't do over 93. What's wrong? Maybe using the wrong port for eathernet cable?? Some other setting???
Message 1 of 2
microchip8
Master
Re: R6080 router doesn't do 300 megs
This model only has 100 Mbps ports. NG refers to WiFi to WiFi transfer. You should pick up a model with 1000 Mbps (1 Gbps) ports
Routing: NETGEAR RAX43 - Firmware: v1.0.11.112 (1 Gbps down, 50 Mbps up)
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (JGS516v2)
Desktop: AMD Ryzen 7 3700X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400, 20 TB
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 228 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
