Orbi WiFi 7 RBE973
Reply
R6220 AC1200 smart wifi router dual band firmware update
edan7
Tutor
Home use of AC1200 smart wifi router model R6220 running V1.1.0.50_1.0.1 firmware.
Nighthawk app says firmware out of date.
routerlogin firmware upgrade assistant says no new firmware version available.
Is it or isn't it in need of update?
If so, where/how can it be accessed?
Thank you.
Model: R6220|AC1200 Smart WiFi Router with External Antennas
Message 1 of 2
antinode
Guru
Re: R6220 AC1200 smart wifi router dual band firmware update
> [...] where/how can it be accessed?
      https://community.netgear.com/t5/x/x/m-p/2029837#M178900
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 280 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
