Reply
Highlighted
Follower
R6220 Firmware update
Just noticed my firmware is Version 1.1.0.34_1.0.1.   Checked for firmware upgrade and showed there were none.  Any suggestions?
Model: R6220v2|AC1200 Smart WiFi Router with External Antennas
Message 1 of 2
Highlighted
Guru
Re: R6220 Firmware update
> Just noticed my firmware is Version 1.1.0.34_1.0.1. [...]
   So?
> [...] Checked for firmware upgrade and showed there were none. [...]
   "Checked" _how_, exactly?
> [...] Any suggestions?
   Visit http://netgear.com/support , put in your model number, and look
for Downloads. (For older versions, under Firmware and Software
Downloads, look for "View Previous Versions".)  Find the kit(s).
Download the kit(s) you want.  Read the "Release Notes" file for
instructions.  (In the User Manual, look for "firmware", and,
especially, for a topic like "Manually Upload Firmware to the Router".)
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 104 views
  • 0 kudos
  • 2 in conversation
Announcements
