Orbi WiFi 7 RBE973
Reply
R6350 bricked after update
Bluewolf21
Initiate
A few days ago I tried updating to R6350_V1.1.0.78_1.0.1 with the nighthawk app. (Yes, I found out that updating through the app is not a good idea) Now the router boots up and the power and usb lights alternate with no internet.
I have tried to do a hard factory reset already with no success.
Next, I went through the steps to attempt tftp (https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP) but I haven't got it to work yet.
When I ping the router I get something like this:
C:\Users\Family>ping 192.168.1.1
Pinging 192.168.1.1 with 32 bytes of data
Reply from 192.168.1.10: Destination host unreachable.
Request timed out.
Then when i try tftp i just get:
C:\Users\Family\Desktop>tftp -i 192.168.1.1 put R6350_V1.1.0.78_1.0.1.img
Connect request failed
Should I keep trying tftp or is it toast?
I have also seen an article talking about opening the router to fix it. I am willing to try this if it is the only option left.
Message 1 of 4
Accepted Solutions
Guru
Re: R6350 bricked after update
TFTP is sensitive to timing. try it a few times. Also, try watching an instructional video. it can help.
If it doesnt work, you can try nmrpflash.
are you on windows? if so, follow this guide
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Message 2 of 4
All Replies
Guru
Message 2 of 4
Bluewolf21
Initiate
nmrpflash worked! thank you so much
Message 3 of 4
Guru
glad it worked!
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1484 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
