Orbi WiFi 7 RBE973
Reply
R6350 router keeps dropping traffic on specific games
It happens whenever I play games like Left 4 Dead and Super Smash Brothers Ultimate. The connection drops for a second, but relaunching the application fixes it. When playing Left 4 Dead, I can't join public games, else i'll get kicked out in around 5 minutes. I went into the logs of my router, and saw this;
[DoS attack: ACK Scan] from source: 52.94.231.48:443 Monday, November 11,2019 18:42:02
[DoS attack: ACK Scan] from source: 52.202.15.194:443 Monday, November 11,2019 18:39:23
[DoS attack: ACK Scan] from source: 18.207.158.11:443 Monday, November 11,2019 18:38:17
[DoS attack: ACK Scan] from source: 18.207.158.11:443 Monday, November 11,2019 18:37:46
[DoS attack: ACK Scan] from source: 52.202.15.194:443 Monday, November 11,2019 18:37:23
[DoS attack: ACK Scan] from source: 18.207.158.11:443 Monday, November 11,2019 18:37:01
[DoS attack: ACK Scan] from source: 52.94.229.215:443 Monday, November 11,2019 18:36:38
[DoS attack: ACK Scan] from source: 18.207.158.11:443 Monday, November 11,2019 18:35:46
[DoS attack: ACK Scan] from source: 52.202.15.194:443 Monday, November 11,2019 18:35:22
[DoS attack: ACK Scan] from source: 17.57.144.53:5223 Monday, November 11,2019 18:33:50
[DoS attack: ACK Scan] from source: 52.202.15.194:443 Monday, November 11,2019 18:33:21
[DoS attack: ACK Scan] from source: 17.57.144.53:5223 Monday, November 11,2019 18:32:00
[DoS attack: ACK Scan] from source: 52.202.253.199:443 Monday, November 11,2019 18:29:35
[DoS attack: ACK Scan] from source: 52.202.253.199:443 Monday, November 11,2019 18:29:15
How do I fix this? It's been happening for a while and I just want to play l4d, man 😞
Model: R6300|Dual Band 11ac WiFi Router R6300
Message 1 of 13
Accepted Solutions
Guru
Re: R6350 router keeps dropping traffic on specific games
Message 12 of 13
All Replies
Guru
1. What modem are you using? (model number)
2. What firmware is on your router?
3. How are you connect to the router? Wireless/wired.   If its wireless, what wireless adapter are you using and what radio are you using (2.4ghz/5ghz)
4. Are any other games having this issue or just that specific ones?
5. any other devices having this issue?
Message 2 of 13
Guru
And what router are  you using?  your title has the r6350 while the signature line on bottom has r6300
Message 3 of 13
1. R6350
2. Auto updates are on, so the latest one
3. Wired. I'm also connected wirelessly on my switch, with the same issue. (5ghz)
4. From what I can see, it's just left 4 dead and Super Smash Brothers Ultimate. Sometimes I get issues with Starcraft 2, but not consistently.
5. Just my Nintendo Switch and my Windows 10 PC.
Message 4 of 13
Guru
Modem you're using?
Message 5 of 13
Spectrum / Charter Communications. I'm not sure which one specifically, but it was provided by them.
Message 6 of 13
Guru
This would be the forum for the R6350. not the nighthawk forum.
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
Message 7 of 13
Guru
Really doesn't tell me much. Reason why I ask is some of those units have built in routing function. if it does, it can cause a double nat which can cause issues with gaming.
https://kb.netgear.com/30186/What-is-Double-NAT
And a firmware number helps more than "the latest". you'd be surprised at how frequently people aren't "on the latest" or the app doesn't show the latest update. Plus for the people who use this is the future, they have a reference for which firmware you're on.
Message 8 of 13
I'm only using one router so I'm not sure if double-NAT is a problem.
The firmware version is V1.1.0.52_1.0.1, and I really don't know what type of modem I have
Message 9 of 13
Guru
There should be a label on the back of the modem with a model number.
Message 10 of 13
Message 11 of 13
Guru
Maybe those games need an open nat to function. Not sure as I'm not a gamer.
https://kb.netgear.com/23020/Opening-ports-for-internet-games-and-applications-on-NETGEAR-routers
Message 12 of 13
Changing the default DMZ server to my PC seems to have fixed the issue. Also, the OPEN-NAT thing worked, too. So, yay!
Message 13 of 13
Top Contributors
Discussion stats
  • 12 replies
  • 3427 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
