Reply
R6400 constantly drops 5G signal
undgrad00
I know that this subject has been prolific with Netgear routers, but I have not seen any solid solutions. I loose my 5G side several times per day. Before i scrap this router and move to another brand, has anyone heard of a solution?
I have the current firmware and have tried changing channels.
Thanks,
D.
Model: R6400|AC1750 Smart WiFi Router
Message 1 of 4
myersw
Master
Re: R6400 constantly drops 5G signal
Thanks,
D.
You are correct. netgear does not seem to be able to provide decent firmware now and has not been. Sold a r8000 and r8000p due to on going firmware issues. Decided to move on. Would suggest you do the same IMHO.
--Bill
ISP Comcast, Modem-Netgear CM1150V, Router-Unifi Security Gateway-Pro4, AP-2 Unifi AP-LR
Tesla > Edison
Message 2 of 4
DarrenM
NETGEAR Moderator
Have you tried to enable Impact beam forming in the advanced wireless settings?
DarrenM
Message 3 of 4
undgrad00
Hi Darren,
I work from home and require a stable and relaible iternet connection. I have been working on this for over 6 months,including several service calls to my ISP thinking it was them. After reviewing the discussion forums it is pretty obvious that Netgear has a chronic problem across most of their wifi platforms. I'm sure they will eventually figure it out and send a firmware fix, but I am not interested in waiting any longer. I bought an ASUS router andsofar itisperformingflawlessly. Ironically they guy I bought it from had the exact same issue with his Netgear router. Sofor me the solution was to switch manufacturers.
Thanks for the suggestion.
Best,
David
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 655 views
  • 0 kudos
  • 3 in conversation
Announcements
