Reply
R6400 not reaching 1Gbps speed after upgrade
Jason411
Follower
I had been using AT&T 300Mbps and recently upgraded to 1000Mbps.  If i connect directly to the modem i do see around 900+Mbps, but only see 240~Mbps when either wired or on the 5GHz wifi.  I'm on the latest firmware and have rebooted both devices a few times now with no change.  Any thoughts how to get it to switch to the gig speed?
Model: R6400|AC1750 Smart WiFi Router
Message 1 of 3
DarrenM
Sr. NETGEAR Moderator
Re: R6400 not reaching 1Gbps speed after upgrade
Did you ever try a full factory reset on the router?
DarrenM
Message 2 of 3
myersw
Master
Properly designed firmware would never, or rarely, require a reset and reconfigure to make things, maybe work. I never have had to reset my Ubiquiti router after install. Have done numerous firmware updates and never a reset.
Is Netgear ever going to get their firmware act together? There appears to be no oversight, no test for known problems being fixed, no QA before post/ship. The 3rd party firmware engineers should be fired as they have proven they do not have a clue. The poor firmware is what drove me away from Netgear. Used to be my go to.
--Bill
ISP Comcast, Modem-Netgear CM1150V, Router-Unifi Security Gateway-Pro4, AP-2 Unifi AP-LR
Tesla > Edison
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 330 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
