Reply
Highlighted
R6400 slow download speeds (which firmware)
Hello.
I was looking for solution but i didn't found any. So i have r6400 v2, and i changed my plan for 1 gigabit from comcast.
After 3 days of having speeds around 250mbps i decided to call comcast support and I asked them why they didn't changed my plan. But they said that i have 1000mbps internet, so i decided to find a problem.
I found a problem, a firmware. I updated it to last version but it made it worse, i had speeds around 180/200mbps.
Then i downgraded firmware to 1.0.2.52_1.0.39 version, results - 580mbps download 44mbps upload.
It's still half of speed which i supposed to have, that's why i'm asking you, which version of firmware will work for me to have full speed.
Model: R6400|AC1750 Smart WiFi Router
Message 1 of 14
Highlighted
Guru
Re: R6400 slow download speeds (which firmware)
What modem are you connected to?
After the firmware change, factory reset the device. During setup make sure to leave access control, parental controls, qos, and traffic monitoring all disabled.
Also make sure to test hardwired in and test multiple sites. Even speedtest.com doesn't always pick the fastest server.
CAX80-> RBK53-> GS716v2-> TP-Link M9Plus
Message 2 of 14
Highlighted
CM1000, I've tried everything u said. It doesn't help. All i know there's problem with firmware, and i need version which help me to reach 1000mbps.
Message 3 of 14
Highlighted
Guru
what speed do you get connected directly to the modem?
Message 4 of 14
Highlighted
920mbps
Message 5 of 14
Highlighted
Guru
And the speeds you're getting from the router, are those wireless or hardwired?
Message 6 of 14
Highlighted
Wired
Message 7 of 14
Highlighted
Guru
have you tried enabling ipv6?
Changing cables?
Message 8 of 14
Highlighted
I've tried to changed Cables but IP6V nope. I will try do it when I will be at home.
Message 9 of 14
Highlighted
Okay so IPV6 was turned ON. So still there's a problem.
Message 10 of 14
Highlighted
Guru
Do this.
Install version 1.0.3.66 of the firmware. After the install and reboot, factory reset it using the built in factory erase (advanced---->administration---->backup settings---->erase)
then when its fully erased and rebooted, test the speeds right off it with nothing changed. not ssid. just straight from factory.
Message 11 of 14
Highlighted
download 604mbps right now and 42mbps upload.
Message 12 of 14
Highlighted
Guru
might be bumping up against its max. https://www.smallnetbuilder.com/wireless/wireless-reviews/32812-netgear-r6400-ac1750-smart-wifi-rout...
Message 13 of 14
Highlighted
But i have R6400v2
Message 14 of 14
Top Contributors
Discussion stats
  • 13 replies
  • 312 views
  • 0 kudos
  • 2 in conversation
Announcements
