Reply
R6400v2 Speed issue
Allah
R6400v2 Speed issue
hi i created a topic about this back in 2019 and the issue still isnt resolved . my internet speed is 500/500 mbps , im able to get those speeds on the V1.0.3.66_10.0.50 software , but when i update the firmware my speeds drop to 200 mbps or less . i tried rebooting and factory resetting . i went back to the previous V1.0.3.66_10.0.50 firmware and speeds are back to normal. is this going to be fixed?
Message 1 of 19
Guru
Re: R6400v2 Speed issue
We're not netgear. this is the community support forum where members of the public help out. so we dont' know firmware plans or what netgear is working on.
Current Setup: CM2000-> RBK750-> GS716v2-> RAXE500-> Pi-hole->
Message 2 of 19
Is this it?
Speeds decreased in latest firmware update ( R640... - NETGEAR Communities
There is far too little information there to allow anyone to begin to suggest what might be going on.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 3 of 19
Allah
with the latest firmware V1.0.4.118_10.0.90 my speeds have dropped from 500/500 to around 200/150 , on firmware version 1.0.3.66 i was getting 500 down and up , but ever since i updated the firmware im getting no more than 200 mbps . i've been having this issue for a while now. i tried rebooting and factory resetting the router .
Message 4 of 19
It might also help if you told people what the modem is in front of this router, if there is one. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
Just another user.
Message 5 of 19
Allah
im using a modem/ont provided to me by verizon fios
Message 6 of 19
That just says you have a box on the wall. It tells us nothing about what it is and what it can do.
Just another user.
Message 7 of 19
Allah
well assuming you know what a modem is and what it does , i have the verizon fios modem connected to the nighthawk router with a cat 5e ethernet cable. i don't know what else what you want me to include on here.
Message 8 of 19
I sure do. I have owned many over the years.
But modems come in different flavours with a whole raft of possible features. Some do wifi, some do phones, some do handstands.
This will give you some idea of what we are up against:
verizon fios modem - Google Search
If you can find your modem, it probably has a label on the bottom that has a brand name and a model number. Without that information it is impossible to rule out some of the issues that can affect any router you attach to it.
Just another user.
Message 9 of 19
Allah
oh i see , well i cant flip the modem at the moment over to see if it has a model number since its on the wall , but the brand of the modem is verizon . if you search for verizon ont , you'll see it there . im just going to attach a photo i got off the internet , it looks exactly like the equipment i have.
Message 10 of 19
Verizon doesn't make modems. Like all ISPs it buys in and installs stuff like that.
It looks like a plain vanilla ONT. So it shouldn't get in the way of your router.
Just another user.
Message 11 of 19
Allah
oh thought they did since it has a verizon logo on it , and when i had spectrum their equipment didnt have a spectrum logo on it , it just had the logo of the manufacturer on the router/modem . but yeah anyways im just trying to figure out why the speeds have decreased ever since the more recent firmware updates.
Message 12 of 19
Allah
so am i going to get help?
Message 13 of 19
Possibly not, given that this one seems to be unique to you. That usually points back to stuff at your end.
I assume that you have tried all this input:
Search - NETGEAR Communities – R6400V2
Just another user.
Message 14 of 19
Allah
This isn't an issue on my end though . This has to be a issue with the newer firmwares of the router . The problem only occurs on the newer firmware , if i were to go back to the older firmware the speeds would go back to how it should be .
Message 15 of 19
Guru
Have you tried just downgrading? I've seen multiple issues on the newer firmware.
Message 16 of 19
Allah
Yes and the speeds were good but theres security flaws on the older firmware.
Message 17 of 19
Guru
So you have a choice.
Keep the current firmware and speed and hope there will be a firmware that comes out quickly to fix the issue.
Or downgrade and hope the "security fixes" aren't that significant since netgear doesn't release what the actual fixes are.
In my experience, I'd downgrade. I've had routers that didn't get a single update and didn't have anyone penetrate my equipmen/system.
but it is a risk you take.
Message 18 of 19
Netgear will not, and should not, explain what security fixes are designed to mend. To do so would tell the evil people out there that there are unplugged holes in the dyke.
But a cursory glance at the long list oif security issues that Netgear warns about will quickly reveal that most of them are hypothetical. Something uncovered in one of those security labs somewhere but that have never been seen in the wild.
Security Advisory | About Us | NETGEAR
Some people go for years without firmware updated for security fixes. (One recent visitor here is using a router that hasn't had an update in near on-five years, with no seeming damage to their security.)
Just another user.
Message 19 of 19
Top Contributors
Discussion stats
  • 18 replies
  • 354 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
