Orbi WiFi 7 RBE973
Reply
R6400v2 firmware corrupted
andresbarrones
Hi I have a problem with my R6400v2 router. I tried to install the TomatoFirmware firmware but it seems that there has been a failure in the installation and the system has been corrupted.
The router does not stop restarting, I leave you a video for you to see. Any advice on what to do or how I can solve this error.
I have already reset the factory with the back button but nothing keeps doing the same.
Model: R6400|AC1750 Smart WiFi Router
Message 1 of 4
Accepted Solutions
Guru
Re: R6400v2 firmware corrupted
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
If that doesn't work, check on the tomato forums as they'll be more familar with undoing what their firmware did.
Message 4 of 4
All Replies
BobBaniak
Tutor
It doesn't exist and there has never existed Tomato software for R6400v2. Sorry.
Message 2 of 4
andresbarrones
ok but do you have any idea how to repair the device?
Message 3 of 4
Guru
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2426 views
  • 1 kudo
  • 3 in conversation
Announcements
Orbi WiFi 7
