Orbi WiFi 7 RBE973
Reply
R6400v2 stopped working LEDs briefly come on and then go out when turned on
eyestoney
Follower
I purchased my R6400v2 Router about 18 mo ago. It's connected between my cable modem and PC via Cat5, and wirelessly to my laptop, phone & tablet. It was working fine, then from my PC I lost internet and the connection to router over Cat5 from PC. Also lost internet over wireless, even though it still showed a wireless connection to the router. Checked my internet modem by connecting direct, it was fine. So I rebooted the router. But when I switched it back on, most lights flashed on for one second and then went dim, but the power light did not light up at all.  I checked the adapter & its putting out 12.28v. I tried using an older adapter from a previous netgear router and the same thing happens. I've made no changes to my system and power connects through an APC UPS. I have not updated the firmware in some time, so I dont know if it needs updating.
Model: R6400|AC1750 Smart WiFi Router
Message 1 of 2
Accepted Solutions
DarrenM
Sr. NETGEAR Moderator
Re: R6400v2 stopped working LEDs briefly come on and then go out when turned on
I suggest contacting support if your router is still under warranty.
https://www.netgear.com/support/contact.aspx
DarrenM
Message 2 of 2
All Replies
DarrenM
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 898 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
