- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R6700 Firmware update kills router
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried to update per the insturctions sent 12/1/2017.R6700-V1.0.1.36_10.0.40
except I did it over a wireless connection and now I cannot communicate to the router even when directly connected through ethernet. Help
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
After trying a TFTP update with a Netgear Support agent, I was given an RMA to return the unit which I did. That should solve the problem.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6700 Firmware update kills router
I tried to press the factory reset button in the back of the unit for 7 seconds but nothing happens. Is there some indication that the factory rest was completed?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes. It is in the manual. Check the power LED.
There is a manual for the R6700 somewhere at the end of this link:
>>> R6700 | Product | Support | NETGEAR <<<
See page 169.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the help. The power button is blinking white. User manuel says that means firmware is corupt and to contact tech support. Is this tech support? What next?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the input. The firware update seemed to complete based on the on screen progress bar except at the very end when it did not return to the completed update screen. Is my 14 month old router now toast?
- Mark as New
- Bookmark
- Subscribe
- Permalink
So if the bar hits 100% and nothing happens it's likely the router still rebooting so just wait another min or so and like I said close the tab and open a new one and try to login. It happened to me with the latest update a few min ago actually. I was able to log back in again. Sometimes the update and reboot process takes longer than that bar actually shows.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks but I rebooted the router after waiting about 5-10 min for it to recover. Now I still have blinking white light on the power button. I do an ipconfig hardwired to the router and no IP for the router. Press the reset button and nothing happens. I tried using tftp2.exe to force an update but since the router has no ip number, it fails.
- Mark as New
- Bookmark
- Subscribe
- Permalink
When I say reset button I don't mean the toggle switch I mean the one you need like a small pin for. If you did do that (cause you mentioned reset) then just do what I mentioned above.
I've had the router for quite a while and it's been fantastic. It has no issues handling lots of devices connected. It also has really good range and wall penetration. Though if you were to choose a different brand it would be understandable but unless you go really high end like in the thousands of dollars then they are pretty much all the same
Just stay away from Archer routers. They are crap. I had 3 different models before I gave up and bought this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did press the reset pin hole button with a paper clip and nothing happens. This router is 14 months old so it's 2 months out of warranty which is very disappoiting that it fails so soon. It was working just fine before the dumb firware update.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Some people have found that it helps to push the thing for even longer, try a minute. Remember, do it with the power on.
This is an alternative:
- Press reset for 30 seconds
- Keep pressing reset while removing power
- Keep pressing reset for another 30 seconds while apply power
Finally, if all else fails:
How to upload firmware to a NETGEAR router using TFTP | Answer | NETGEAR Support
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Tried pushing reset for over a minute with power on. Nothing happens.
Tried pushing reset with power off then power on. Flashing many LEDs. Power LED goes amber for about 1 minute then turns flashing white.
Tried the TPTP option with amber power LED on after pressing reset over a minute. It never turns green like the instuctions say. On the 3rd retry of TFTP, a progress bar indicates firware being updated but fails halfway through.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Mark_53,
If the TFTP will not work, possible hardware issue. I would suggest contacting support team for replacement.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Mark_53,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Dear
my netgear router R6700 is killed after apply your last update .... im so confused and dont understand why? the update is FAKE from Netgear or how?
can you gelp me to recover it
Best Regards
Patrick
- Mark as New
- Bookmark
- Subscribe
- Permalink
The latest update has made my R6700 router unreliable wifi wise, any cure available?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Different hardware, but you might want to try this:
Solved: Re: R6400 router slow after firmware update V1.0.1... - NETGEAR Communities
It has worked for others.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I solved my problem by removing this *** and reinstalling my ten year old Apple Time Capsule; fast. dependable internet again. Netgear can take a hike!
- Mark as New
- Bookmark
- Subscribe
- Permalink
You would be better served buying a $40 router that is current than you would using an old one. Routers, at least consumer ones are notorious for security holes.
Whatever you decide to do just remember that updating via WiFi is always not advised.
That said since your device was bricked by what seems like a bad rom chip I'd call Netgear on the phone and demand replacement and I wouldn't stop until it was replaced. I'd file a complaint with the BBB and my State AG along with maybe even the FTC. Such an expensive router shouldn't die so quickly unless it was abused. It just shouldn't.
Also for future reference keep in mind routers tend to run hot so give them proper air circulation and blow any dust out of them. Heat kills.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I bought this in November of 2016 so would not expect any "help." I used my old Time Capsule since I wanted to access the internet and my newest "old" router, a Cisco E4200, couldn't be activated since I didn't know the password, so enter the Time Capsule. I have downloaded the previous firmware and am searching for instructions on how to "flash" my Highthawk with that. I would like to do it without having to install it in my network.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you mean firmware for the R6700, the Release Notes usually explain what to do.
Start on page 132. But don't use the Check button. Browse to the file that you downloaded. After you have unzipped it, of course.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am going to try this this afternoon. I think I will just try hooking it up to my MacBook Pro with an ethernet cable to see if it recognizes it. Hoping for success here, thanks for your reply.
