Reply
R6700 Has wifi but no ethernet
jahnpahl
Follower
I've been using a 2-in-1 modem/router Surfboard and I set it to bridged mode so that I can connect my R6700 that I got from my friend. Setting it up was smooth, but I don't get any internet from the ethernet ports. Wifi works perfectly fine;I'm making this post on my laptop. The LED for port 4,the one plugged in to my main computer, is blinking white, but I can't access any websites, not even routerlogin.net. On the attached devices, it shows up as Device Type:Network(Generic), not as a computer like this laptop(see attached image).
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 2
Re: R6700 Has wifi but no ethernet
@jahnpahl wrote:
I've been using a 2-in-1 modem/router Surfboard and I set it to bridged mode ...
Can be easier said than done. What model is this modem/router?
Dd you reset the router and set up the network from scratch, doing things in the right older?
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 196 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
