Reply
R6700 [LAN access from remote] from XYZ to Local IP. Help Me Make Sense Of It
CChenry
Follower
Some notes, the local ip address is my main pc,
the port 32400 is for the plex server, I downloaded teh software straight from them.
Whats does this mean? whats going on? are people using my computer? is my computer a proxy for them?
[Admin login] from source 192.168.1.2, Saturday, Jan 12,2019 12:47:07
[LAN access from remote] from MY-IPADDRESS:3657 to 192.168.1.2:32400, Saturday, Jan 12,2019 12:42:06
[LAN access from remote] from MY-IPADDRESS:3651 to 192.168.1.2:32400, Saturday, Jan 12,2019 12:42:06
[LAN access from remote] from 34.247.38.195:54696 to 192.168.1.2:32400, Saturday, Jan 12,2019 12:40:30
[DHCP IP: (192.168.1.6)] to MAC address EC:1F:72:BE:42:7B, Saturday, Jan 12,2019 12:02:26
[WLAN access rejected: incorrect security] from MAC EC:1F:72:EB:36:5B, Saturday, Jan 12,2019 12:02:25
[LAN access from remote] from 54.194.178.55:56952 to 192.168.1.2:32400, Saturday, Jan 12,2019 11:39:56
[LAN access from remote] from 34.248.59.52:40766 to 192.168.1.2:32400, Saturday, Jan 12,2019 09:48:25
[LAN access from remote] from 34.245.172.51:37870 to 192.168.1.2:32400, Saturday, Jan 12,2019 08:47:48
[LAN access from remote] from 34.249.68.164:59092 to 192.168.1.2:32400, Saturday, Jan 12,2019 08:47:01
[LAN access from remote] from 34.249.68.164:33404 to 192.168.1.2:32400, Saturday, Jan 12,2019 07:49:13
[LAN access from remote] from 54.194.178.55:45228 to 192.168.1.2:32400, Saturday, Jan 12,2019 07:32:47
[LAN access from remote] from 34.245.172.51:35832 to 192.168.1.2:32400, Saturday, Jan 12,2019 06:51:29
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 3
Re: R6700 [LAN access from remote] from XYZ to Local IP. Help Me Make Sense Of It
Greetings,
I checked 3 of the IP's.  They were Amazon.
Start here:
Disable UPnP and restart the router gracefully.  Monitor the logs and report back.
Likely has to do with whatever PLEX is streaming.
~Comcast 1 Gbps/50 Mbps SB8200 > R8000P
~R8000P FW:1.4.1.68 ~R7000 FW:1.0.9.42
~R6400 FW:1.0.1.52 ~Orbi-AC3000 FW:2.5.1.8
~EX3700 FW:1.0.0.84
Message 2 of 3
myersw
Master
As @shadowsports said those appear to be AWS (Amazon) servers. If you did not know it, AWS is, I think, the biggest supplier of digital storage which plex obviously is. A large number of the top companies use them for "cloud" storage.
Easy way to check is, if you have a PC drop to command line then enter nslookup IP address.
Example using one of your IP addresses in question.
nslookup 54.194.178.55
Server: Gateway
Address: 192.168.1.1
Address: 54.194.178.55
Probably just normal chatter for plex service.
--Bill
ISP Comcast, Modem-Netgear CM1150V, Router-Unifi Security Gateway-Pro4, AP-2 Unifi AP-LR
Tesla > Edison
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 628 views
  • 0 kudos
  • 3 in conversation
Announcements
