Reply
R6700 Network Key Does Not Work
calliekeeney
Follower
i just purchased a new nighhawk router. i am following the setup instructions but it keeps telling me my password is incorrect when i type it in.  this is the default network name and password and i am being very careful - 100% sure i am typing it correctly. HELP!
Message 1 of 2
Re: R6700 Network Key Does Not Work
Where do you see this error? What are you trying to login into and what with?
There are various passwords involved with routers. For example, there is the one that you use to get into the graphical user interface (GUI) with a browser.
Then there is the password you use to connect to its wifi.
There may be others, so take is through what you are doing and where it goes wrong.
There are several hardware versions of the R6700. Look at the label on the thing to see if there is a V number. If not it is V1.
model number
If you visit the support pages:
Support | NETGEAR
you can feed in the model number and find all the documentation for your hardware.
Just another user.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 238 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
