Reply
Highlighted
R6700 Nighthawk was connecting Dish Hopper3 On Demand for a year. Now all of a sudden its blocked
Prior to 15March 2020 we used On Demand via Dish TV's Hopper3. Netflix and Youtube works. But various On Demand and play back feature cause several different error codes. We are able to direct wire to modeum or use a hot spot and the On Demand and other block features all work. Dish also came out and did the same. Dish states I have to remove the 'extra security fire wall' or On Demand will not work. However Dish convienently has a $400 fix, a mesh radio router. Botton line is the NetGear work fine for a year and can it work again?
Model: R6700|Nighthawk AC1750 Smart WiFi Router
Message 1 of 6
Highlighted
Guru
Re: R6700 Nighthawk was connecting Dish Hopper3 On Demand for a year. Now all of a sudden its blocke
what modem are you using?
CAX80-> RBK53-> GS716v2-> TP-Link M9Plus
Message 2 of 6
Highlighted
Viasat Surfbeam 2
Message 3 of 6
Highlighted
Guru
This?
https://www.viasat.com/sites/default/files/legacy/surfbeam2_terminal_datasheet_139_web.pdf
If so, it has an integrated router. You could be running into a double nat issue.
https://kb.netgear.com/30186/What-is-Double-NAT
Message 4 of 6
Highlighted
Looking at this there is a router in between. My Netgear is directly LAN to the modem. Did hard reset and still nothing. Made sure of the IP address etc etc. It still blocks On Demand library and access.
Message 5 of 6
Highlighted
Guru
If you're going the viasat to the netgear, you're in a double nat. A hard reset isn't going to fix it.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 184 views
  • 1 kudo
  • 2 in conversation
Announcements
