- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
R6700 Setup help
- Mark as New
- Bookmark
- Subscribe
- Permalink
R6700 Setup help
Hello! I just purchased a Nighthawk R6700 AC1750 and had trouble setting up the router. I followed the instructions in the Nighthawk app and everything, but my phone and other devices showed connected but no internet. So i am wondering what is the issue here. I power cycled my modem and the new router several times but it still said no internet. I am replacing the N600 and had to reconnect it back since the new router isnt working properly. Any help? Though, the internet light was blinking constantly, I dont know if that has to do with anything. I am using the specturm modem and the model number for the modem is E31T2V1 and it says DOCSIS 3.1 under it. Thanks in advance!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: R6700 Setup help
What does the Internet LED on the device looks like now?
Is it still blinking? That usually just means "traffic".
What colour? That is the key indicator.
The mobile app is not the best way to set these things up. If possible try a wired connection and follow the QuickStart/Installation Guide.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Remember, as the documentation says, you have to do things in the correct order.
As this is a router, there is probably a modem sitting in front of it. You need to get the devices to forget any inherited settings. Among other things, that means rebooting the network.
Power cuts usually take out both the modem and the router on a network. When the power comes back on, they may start up in the wrong order, with the router starting before the modem is ready. That means that they get confused about which is in charge.
It may help to reboot the whole network in the right order.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you tested to see if you are getting an internet connection from the router? And to factory reset the router if you need to you will want to hold that reset button for 10 seconds with the router powered on.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
